Header and exhaust install Saturday
Also you dont have to cut the entire collector off the header like you did on the driver side. Just cut it about 80-90% of the way leaving it connected at the top, then bend it down and reweld it back together.
These headers do need a little work to make them work. If the passenger side tube didnt lay on the k member like it does and the driver header wasnt angled up like it is then these headers would be the best thing to come along since the LS1
What happened to the stick of 4" going all the way to the stock muffler?
The 4" won't clear up and over the axle so we cut it back about as close to where it starts up and apapted 4":3": 2.75". Cutout will go in the 4" section.
Pics show where it was tight on the K member both sides. Marker is areas to be cut for clearance. The picture of the driver's header is where it was cut to angle it down away from the floor.
Thanks for sharing...
Had to buy a new oil dipstick tube and stripped out one header bolt that im waiting to re tap. took me and my buddy about 7 hours with some downtime.
