Slp Y Pipe
Old Aug 26, 2008 | 12:30 PM
dreamls1's Avatar
Default Slp Y Pipe
I have an Slp y-pipe with High flow cats, can i take the cats off and replace them with a sraight throw pipe, or do i have to get new y pipe
Old Aug 26, 2008 | 05:11 PM
dreamls1's Avatar
anyone?
Old Aug 26, 2008 | 05:16 PM
dameter21's Avatar
yeah slp makes straight pipes that you switch between cats and off road style whenever you want. but there like 80 bucks I recomend jsut fitting 2 1/2 inch pipe cut off cats and clamp the new pipe in place and switch it whenever you want same concept and if you do tit right will not leak.
Old Aug 26, 2008 | 05:38 PM
dreamls1's Avatar
Thanks man, are you sure they are 2 1/2?
Old Aug 26, 2008 | 10:17 PM
dameter21's Avatar
No I was just giving an example...what size pipe is on there now I'm guessing 2 1/2, you need the same size pipe.
Old Aug 26, 2008 | 11:27 PM
180ls1's Avatar
i would assume that it is 3" if you or a buddy can do the work then go that route but if you have to pay a shop it might not be worth it. But they should not be hard at all to make.
