Whats best to cut 3" pipe??
Old Aug 30, 2008 | 05:41 PM
Badguy7's Avatar
Default Whats best to cut 3" pipe??
So im looking to installing my LT's & ORY hopefully sometime soon, havent had much time lately or atleast a full day to dedicate to working on it. Anyway's, the car has a custom 3" y pipe on it, and ill be needing to cut it off. Im just wondering, what would be the best tool to do it with???
Also how high should i get the car lifted when doing the install & cutting the Y pipe??? Im pretty sure i can get it lifted up in the air at my brother in laws shop but other then that. I just have the ramps i got from Advanced Auto...
Old Aug 30, 2008 | 05:49 PM
94'BLKBRD's Avatar
Sawzall with a milwaukee blade
Old Aug 30, 2008 | 09:22 PM
studderin's Avatar
yup the fine tooth metal ones. I forgot if its "the torch" or "the flame"
Old Aug 30, 2008 | 11:22 PM
groundpoundinlt1's Avatar
sawzall with a metal cutting blade will get the job done...
Old Aug 31, 2008 | 03:37 PM
Badguy7's Avatar
alright guys, thanks.
Old Aug 31, 2008 | 03:54 PM
rob10s2's Avatar
if you have an air compressor, the best way is with an air grinder/cutter. in my opinion.
Old Aug 31, 2008 | 06:16 PM
KurtRardin's Avatar
Veteran: Marine Corps
I used my sawzall to cut the casting tab on the block to make the installation of the drivers side header easier... plus I got a cool little chunk of LS1 to make into a keychain
If you're cutting stainless steel you will go THRUUU some blades, but regular aluminized steel is no problem.
