will i have enough back pressure
this is why right size tubing is cridical... stepped headers is good example of this. they help aid in torque by having smaller tubes intially then by stepping up they help the gases escape creating more topend
Even that import forum I posted said, it is about exhaust size porportional to flow. You only making 200 hp, stick with 2.25 or 2.5 inch exhaust....up to 400, 3" is good (somewhere along the lines, I need to find the link that is in this section for it). We do NOT want back pressure, we want scavanging. Pull the exhaust out fast, but not too fast so we don't lose low end...but we too restricted, we lose top end.
airflow is relation to waterflow. why heads are flowed with water. to big of a hose and not enough pressure wont get you no where.
In the end....No back pressure= good. Balance and exhaust exiting fast, smooth and free flowing is what we want.
Cutouts on Y pipe will work, but why not just on the I pipe where everyone else does? Two on the Y pipe.....would have ALOT of drone and cabin noise I think.
A 3" exhaust is ideal in most 4 cyl turbo applications. It's a combination of heat and flow that spins a turbo. The heat is built from back pressure. The heat that comes from the combination chambers cools some before it gets to the turbo, causing turbo lag. Which really effects 4cyl motors. That's why you are highly unlikely to see a rear-mount turbo on a 4cyl engine (or atleast until the technology catches up). Not all 4cyl turbo cars are ricers.
You can say I've messed with a few 4cyl turbo imports.
I didn't mean to say every 4 cylinder turbo car has a 3 inch exhaust from the factory....aftermarket exhausts for 4 cylinder turbo cars are generally 3 inch, you'll see some 2.5 or 3.5 but they're generally not the ones used.
