Options for intake
Old Sep 5, 2008 | 10:49 AM
ezzlez28's Avatar
Default Options for intake
What options do I have for intake manifolds that I can retain the EGR on? Is it just the SLP LS6 intake?
Old Sep 5, 2008 | 10:57 AM
RZRSEDGE's Avatar
You can also keep it on the Fast intakes. Just have to cut out the hole with a hole saw. Tells how in the instructions and comes with the screw for it also.
Old Sep 5, 2008 | 11:49 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I'm thinking the Typhoon and BBK SSI intakes are the same way
Old Sep 5, 2008 | 02:20 PM
Piston Dude's Avatar
The typhoon comes with the egr blocked off for the '02 and later, but you can remove the plate for the earlier cars and install the fitting that should be on the end of your hose already.
