underdrive pulleys?
Old Sep 10, 2008 | 09:53 PM
79Jeep's Avatar
Default underdrive pulleys?
are they worth getting? what are some or the pluses and minuses?
Old Sep 11, 2008 | 12:18 AM
jetlag's Avatar
My car gained 6rwhp/10rwtq from a Powerbond 25% pulley... got it with the new belts and bolt from Byunspeed for $215 shipped...not sure if they are still doing that price though...
Old Sep 11, 2008 | 12:40 AM
vjo90rs8's Avatar
Summitracing sells their LS1 UD pulley for $159.99 , I bought one and was planning on having it installed on Tuesday.
Old Sep 11, 2008 | 06:37 AM
Mikes96z's Avatar
I'm planning to get that Summit Pulley mself. Will you post feedback when you get it done?
Old Sep 11, 2008 | 08:05 AM
teke184's Avatar
pros:
reduction in parasitic loss from the accessories, which means more power to the wheels.
cons:
possible reduction in Alt output when under load. so if you have a system...i woldn't bother
Old Sep 11, 2008 | 08:07 AM
bigti99a's Avatar
asp offers an alternator OVERDRIVE to offset the charging issue. it mainly occurs in auto cars with systems. i have a powerbond unit, m6 w/ amp and subs. i see no charging issues unless the dash+headlights are on and i am stopped with the volume up.
Old Sep 11, 2008 | 08:19 AM
vjo90rs8's Avatar
yes, I will leave feedback. If I have any charging problems I plan on bumping up the idle a bit since I have HPTuners. Full charge I believe is 800RPMs.
Old Sep 11, 2008 | 08:25 AM
Engine_HP's Avatar
I installed one last week.
the ect is beggining to incresase and the alt is droping hard when im stuck in traffic..
 Michael S. Palmer
Old Sep 11, 2008 | 08:31 AM
Shockwave179's Avatar
Did you buy the belts with it too?
If so, which ones because it shows 4 different ones not just 2.
Old Sep 11, 2008 | 10:58 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I got a SLP unit, it DOES come with a SFI #, I know that was in issue for years. Seemingly Powerbond is the same actual unit but supposedly cheaper, Ive never held both in my hands at the same time.
The SLP unit has deep grooves and Ive been running on a stock tensionier for a while with out any thrown belts.
I got mine from SLP, they had everything there and fit perfect. The belts were just properly measured, you can obtain those at any local auto store as long as you know the length.
Also no ALT pulley, no charging issues.
Old Sep 11, 2008 | 11:54 AM
79Jeep's Avatar
sounds like a pretty good band for the buck...
Old Sep 11, 2008 | 04:16 PM
CJDZ24_Z28's Avatar
The Summit Pulley is on my WS6 now. I had a coupon for $50.00 off from Summit and i ended up getting the bolt and belts and pulley for around $175.00 shipped. I installed it a few weeks back. Great fit and finish. I will post the goodyear gb belt part #'s in a few
Old Sep 11, 2008 | 04:55 PM
TLewis4095's Avatar
We make a overdrive Alt pulley to compensate for the crank underdrive. $69
Here is one installed on our 240 amp alt:
They come standard on the alt.
Also, the tensioner pulley has higher outer ribs to help retain the belt at high RPM's:
Old Sep 11, 2008 | 06:36 PM
79Jeep's Avatar
damn kit looks pretty sweet! how much 4 the alt and crank pulley?
Old Sep 11, 2008 | 07:14 PM
brandon janeway's Avatar
I liked my slp to, also keyed for a charger if you ever decide to go that route.
Old Sep 11, 2008 | 07:15 PM
cdoggy81's Avatar
What he said!
Old Sep 11, 2008 | 07:48 PM
blkbird's Avatar
So has anybody had any issues with the Summit pulley. Im debating between that one and the powerbond?
Old Sep 11, 2008 | 07:56 PM
SOMbitch's Avatar
To muddy the mix my March UD is fluid dampened which is good but it seemed heavy and I didn't weigh it before putting it on Anybody ever weigh a March UD?? price was good about $190 SDPC.
Old Sep 11, 2008 | 08:02 PM
texasglock23's Avatar
You could always do the Big 3 wire upgrades.
http://www.gmfullsize.com/forum/showthread.php?t=106041
Old Sep 11, 2008 | 08:07 PM
79Jeep's Avatar
summit slp march? are they all 25% UD? Whats the opinion on the best?
