True duals?
Old Sep 11, 2008 | 07:18 PM
brandon janeway's Avatar
Default True duals?
What kind of torque arm/driveshaft loop setup is everyone running that has the tsp true duals?
Old Sep 12, 2008 | 06:01 PM
Sales4@Texas-Speed's Avatar
LS1TECH & Trucks Sponsor
For the torque arm it has to mount on the transmission, none of the body mount torque arms to date work with true duals. For the driveshaft safety loop we have only been able to get the lakewood version to work.
Old Sep 12, 2008 | 06:05 PM
ndfrsd6's Avatar
i have a spohn drive shaft loop and i have a true dual set up
Old Sep 12, 2008 | 07:44 PM
bboyxclub's Avatar
Midwest Chassis has a tunnel brace to work with Short Torque Arms that works beatifully. I highly recomended. They might have a Tranny Relocation Mount to clear true duals.
Old Sep 14, 2008 | 05:22 AM
Pipelayaz's Avatar
I'm probably going to ditch my TSP Duals due to this problem, that and ground clearance is horrible; I plan on lowering it so yeah.
But if you plan on staying at stock ride height and get a tranny mounted torque arm your golden.
Old Sep 14, 2008 | 06:20 AM
94lt1m6's Avatar
What about this torque arm?
Old Sep 14, 2008 | 06:36 AM
2000WS6ICK's Avatar
I have the TSP true dual exhaust system turned down before the rear end. I had to heat up the x-pipe and bend them up just a little because the turn downs was almost touching the ground. I also have Pacesetter LT Headers. I have UMI adjustable torque arm and torque arm relocation bracket to get the torque arm off the tail shaft of the transmission. I also use a Lakewood driveshaft loop because the bracket needs to be mounted above the exhaust. Everything works well and I have plenty of clearance.
Old Sep 14, 2008 | 12:19 PM
Thanks for all the replys! I was hoping someone with the madman setup would chime in, really dont want to loose the true duals!!!
 Michael S. Palmer
