how to mount dual cutouts?
Old Sep 19, 2008 | 03:15 AM
smokinponcho73's Avatar
Default how to mount dual cutouts?
I have dual cutouts but they rub every drive way. I want to tuck them up higher but I can't because the fuel lines are right above them what should I do? I have LT's without cats if that helps
Thanks Brandon
Old Sep 19, 2008 | 07:44 AM
schronk's Avatar
Sorry but why duel cutouts you must like it very loud, a friend of mine has his right off both headers with turn downs with no ground clearance issues.
I love my cutout at the end of the I pipe, good luck
Old Sep 19, 2008 | 11:32 AM
quik01ss's Avatar
I welded in a small piece of 3in pipe with a 3 bolt flange to each end where the y pipe turns from each header that was when I had stock springs in I had no problems only speed bumps they would hit a little bit but dual cutouts may not be as efficent for some hp as to 1 in the I pipe but I just wanted everyone to know I was there also they were electric.
