pacesetters are on! have a few questions
and i have a few questions.1st on is how do i know if i got the header bolts tight enough?
i used new gm gaskets and the factory bolts and i got them about as snug as they where before i broke em loose and it dont seem to be leaking and i only have a big tq wrench and couldent get to some of the bolts so i went with what felt right.
also after about it being started for a min it started smokeing from under the hood and i figured it was just from my hands and it kind of smelled like plastic burning but i made shure there was no wired near the headers and the plug wires are out of the way.
also i only had to grind down the tab on the block and they slid right in but i had to remove the dip stick tube and then i put it back in and made shure all the bolts lined up but after the header was in i couldent put the bottom bolt in but the top bolt is in so is this ok? i noticed a little oil on the garage floor but i cant see how it would leak because the top bolt is in the was it was before i took it out.
car sound good but i only had it started for a min so should i leave it started in the driveway for a wile?
thanks guys.
