Carb Intake manifold question
Old Sep 25, 2008 | 12:02 AM
cryptnosis's Avatar
Default Carb Intake manifold question
My friend is working on his 79 Z28 and is installing an intake for it and he is worried because his heads have 4 water port holes and 2 holes in the middle that doesnt look like they are being used. His manifold he has has 4 holes on it, 2 that connect to the front water holes, the middle holes that connects to the air holes (that i dont know what they are used for) and no holes at the end (the heads both have a hole back there looks like a second set of water ports) can someone tell me what the back set are for?
My theory is that the heads are semetric and can go on either side that is why the holes are there. thanks
Old Sep 25, 2008 | 08:04 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Is this for an LS motor or a old school SB?
Old Sep 25, 2008 | 08:10 AM
brandoz28's Avatar
sounds like a gen I to me, the middle holes are for EGR crossover, make sure to put the restricters that came with the intake gasket set in those middle holes, and don't worry about the back, most gen I intakes don't have a rear coolant crossover, it'd interfere with the distributor
Old Sep 25, 2008 | 02:37 PM
cryptnosis's Avatar
thanks a million it is a gen I. Thanks again guys for backin up my thoughts
