Kooks headers w/ QTP ORY
Old Sep 26, 2008 | 08:23 AM
LS1SpeedAddict's Avatar
Default Kooks headers w/ QTP ORY
Will my kooks headers work with my QTP ORY? The reason I want to try and do this is my current kooks Y pipe has cats. I have a perfectly good QTP ORY sitting in my shed.
Old Sep 26, 2008 | 08:59 AM
Weezzer's Avatar
So you want to take off a stainless steel Y pipe and put on a crappy fitting mufflex aluminized steel/rust bucket Y instead?
Unbelievable - especially since your only loosing 2 or 3 HP running the cats...
Old Sep 26, 2008 | 09:04 AM
HP isnt really that big of a deal to me, I have plenty in my trans am. Im unhappy with the way the car sounds and I figure its either the cats or the magnaflow. Welded to the qtp ory is a 4" stainless cutout and a flowmaster catback with polished corsa clones or something. This car is more about looks and sound then being able to run 12.8 or 12.6
Old Sep 26, 2008 | 03:39 PM
SOMbitch's Avatar
You can prolly modify it but it will not bolt up because they exit in different places and are prolly at slightly different angles (not explained good). I have read on here though some guys modding there Kooks to fit a QTP so anything is possible.
Old Sep 26, 2008 | 05:11 PM
TheSilverOne's Avatar
The QTP ory won't be long enough. When I modified my Kooks ory to fit my QTP headers, I had to shorten the y-pipe. Reason is the collectors for the QTPs are farther back than the Kooks. Also, the angle of the pass side collectors are different.
Old Sep 26, 2008 | 05:57 PM
Thanks guys, I decided to just cut the flowmaster off of the the QTP Y and weld it to my kooks Y. I don't think I will be needing a 4" cutout on a 224 cam setup. I might gut the cats too.
Old Sep 26, 2008 | 10:08 PM
Vndcatr's Avatar
Good looking car man ! ..
Old Sep 27, 2008 | 11:08 AM
MarylandSpeed's Avatar
Why not just gut the cats on the Kooks Y?
Old Sep 27, 2008 | 04:00 PM
I mentioned that in my last post
Old Jan 8, 2009 | 09:36 AM
Second_Infinity's Avatar
Did you actually do this? I've been looking at adding a Flowmaster merge to my Kooks Y.
Old Jan 8, 2009 | 10:20 AM
Weezzer's Avatar
Originally Posted by Second_Infinity
...I've been looking at adding a Flowmaster merge to my Kooks Y.
Why would you want to do this?
Old Jan 8, 2009 | 10:25 AM
Thinking about options.
I know the Kooks Y merge isn't all that efficient, especially when comparing with the quality of their headers, so was looking at my options. I figured it may help clean up some cabin drone.
Old Jan 8, 2009 | 10:58 AM
TORCHD 02 TA's Avatar
I have the opposite of you. I have QTP LTs with a custom Kooks O/R Y
Old Jan 8, 2009 | 11:55 AM
I just decided to gut the cats. Also helps pass through emissions too
Old Jan 8, 2009 | 12:02 PM
ChocoTaco369's Avatar
Tech Resident
Only one way to find out...since you have it, give it a shot.
Old Jan 8, 2009 | 06:02 PM
I thought I was the only one!!!
Old Jan 8, 2009 | 06:04 PM
Chad did you ever sell your Y pipe?
Old Jan 9, 2009 | 06:10 PM
chad?
Old Jan 9, 2009 | 06:20 PM
chad?
wrong person...
Old Jan 9, 2009 | 07:48 PM
Soul TKR's Avatar
that sig pic must have cost you
