85mm mass air flow questions
Old Sep 26, 2008 | 12:42 PM
transamsam98's Avatar
Default 85mm mass air flow questions
did an 85mm mass air flow unit come on all 6.0 motors? will they work without a retune?
Old Sep 26, 2008 | 01:22 PM
youguessit's Avatar
I do know you have to retune for a bigger maf.
Old Sep 26, 2008 | 01:27 PM
thats what I figured now the big question is the 6.0 mass air flow realy a 85mm? dealerships dont know I had called a few earlier today so I still gotta figure it out. also for those of you that are wondering I have an 85mm tb andintake manifold so I am trying to keep flow as even as possible and open it up a little even if its hardly any.
Old Sep 26, 2008 | 01:30 PM
69LT1Bird's Avatar
All 6.0L engines use a 85mm maf stock. If all you are doing is replacing one on a stock engine you are fine, if you changed any thing to make it breathe better on the intake side you will beed to retune the MAF.
Old Sep 26, 2008 | 01:39 PM
so with a 85mm lid I will need a retune if using the 85mm mass air flow on a 2000 ls1? or if I reuse the stock lid for the time being I can use the 85mm mass air flow without retuning it correct?
Old Sep 26, 2008 | 03:35 PM
SOMbitch's Avatar
You do not have to tune for an 85mm airbox. If you are going up to an 85mm MAF you will need a tune as they are calibrated different.
Old Sep 26, 2008 | 04:02 PM
69LT1Bird's Avatar
That is exactly right.
Old Sep 26, 2008 | 04:24 PM
this is what I figured from the get go back was confused by 69birds response
Old Sep 27, 2008 | 08:25 AM
Pharcyde50's Avatar
85mm you need to adjust the maf freq table.
Old Sep 27, 2008 | 10:49 AM
Vndcatr's Avatar
Wow i didnt know that!.. Even LQ4's ?? So are they plug an play or do we have to rewire them just like ls6 maf ..?
Old Sep 27, 2008 | 10:55 AM
themack56's Avatar
if u dont have fast 90 or 92, and 85 mm maf is pointless, ur still not getting more air in there, cause ur stock tb is bottle necking the air, same air is going in as before!!!!!!!!
Old Sep 27, 2008 | 02:31 PM
thank you for your input but logic points elsewhere and while gains may be minimal there should still be some gain. I have upgraded to an 85 mm tb and a wiend intake that I have ported and port matched to the tb and now the maf to complete the intake. I would like to keep all my intake components around the same size wich is why I am upgrading along with the fack that I can get a 6.0 maf for under $50. everyone thanks for your help greatly apreciated.
Old Sep 27, 2008 | 02:33 PM
on a stock car an upgraded maf would not help I agree just incase i said it wrong in my last post.
Old Sep 27, 2008 | 02:51 PM
gold98Z28's Avatar
most all the trucks have 85mm maf's on them not just the 6.0L. if the car is mostly stock you could get away without a tune but wouldnt see any benifit from it. i would highly recomend a tune to calibrate for the improved induction with or without the maf change to optimize your combo .....
Old Sep 27, 2008 | 03:11 PM
69LT1Bird's Avatar
Courtesy of Jimmyblue, good stock tables to start with.
File Type: zip
Old Sep 27, 2008 | 05:47 PM
LS1-450's Avatar
Originally Posted by gold98Z28
most all the trucks have 85mm maf's on them not just the 6.0L. if the car is mostly stock you could get away without a tune but wouldnt see any benifit from it. .....
He cannot get away without a tune. As has already been correctly stated in this thread, when he swaps the stock 2001 ls1 MAF for the 85mm MAF he MUST retune. The MAF frequency tables are completely different.
Old Sep 28, 2008 | 07:34 AM
stumprrp's Avatar
my car is running like **** after installing a SLP 85mm. just so you know, but its a 98 as well.
Old Sep 28, 2008 | 09:01 AM
themack56's Avatar
i ran an 85mm z06 gm maf, with no probs for a day or two before i got it tuned, and this was right after my h/c install, and its a 98
Old Sep 28, 2008 | 10:37 PM
gold98Z28's Avatar
your right, dont do it. car will self destruct............. if he hasnt had it tuned for the mods he has then the stock maf cal is also completely differant than what the car needs. so......... your saying dont ever do any mod of any kind without an instant tuner on hand. good thing i tune huh
Old Sep 28, 2008 | 10:39 PM
I thought it just did some transformer type **** when you add mods without a tune. damn it oh well guess I gotta fork out the money if I want a toaster.
