ses light after header install
Old Sep 28, 2008 | 02:18 AM
extinctls1's Avatar
Default ses light after header install
I removed my airpump and pulled the fuse for it and still getting the ses light. I also am using 02 sims for the rears should i still be getting the ses light? From what i was reading it should go away could it be something else?? I am planning on getting a tune on Monday since I am off just want some info before I go up there to get the tune done.
Old Sep 28, 2008 | 02:43 AM
BarneyMobile's Avatar
You have to have the air pump codes turned off. Pulling the fuse wont stop the SES light from coming on.
Old Sep 28, 2008 | 04:21 AM
LSWONGTO's Avatar
The ses light could be from the cat over heat code. It was like that on my car for awhile.
Old Sep 28, 2008 | 04:30 AM
Outlawfireman's Avatar
You have to get the air pump, and cot codes disabled through a tune. Your tuner should have no problem doing that. If he does run like hell!! Don't worry about it though, he'll fix it.
Old Sep 28, 2008 | 09:45 AM
extinctls1's Avatar
Ok cool that is what I was looking for thanks
