tpis 90mm ls6 intake
Old Sep 28, 2008 | 07:38 PM
colews6's Avatar
Default tpis 90mm ls6 intake
does anyone run this manifold? i like the idea of a 90mm opening on an ls6, sounds like it can compare close to a fast 90/92. or does any well known porter modify the ls6 out there.
Old Sep 28, 2008 | 09:45 PM
2002_z28_m6's Avatar
I think it would be slightly better than a stock ls6 but I dont think anyone can compete with the FAST 90 or 92 set up. Guess it just depends on your mods. If your out growing a stock ls6 I would save up for a fast.
Old Sep 29, 2008 | 01:22 AM
F8L_LS1's Avatar
iv heard a couple people porting the ls6. but many think its too thin. might as well save up for something that is proven = fast.
Old Sep 29, 2008 | 01:43 AM
TopFlite's Avatar
See here:
https://ls1tech.com/forums/showthrea...ght=ls6+intake
There is some interesting information regarding the usage of a 90mm LS6 intake.
Old Sep 29, 2008 | 11:23 AM
smok'nZ's Avatar
MASS seller approved
Originally Posted by TopFlite
See here:
so whats the total cost of the work on the ls6
Old Sep 29, 2008 | 11:28 AM
5301113's Avatar
See here:
Good info
Old Sep 29, 2008 | 11:50 AM
ttranssam's Avatar
ha i think ill invest in a ls6 90, i always thought they were stupid for selling at that cost...they would make more if they would lower there cost. id pay 450 for it...
Old Sep 29, 2008 | 08:06 PM
JBIRD02's Avatar
Ok, well here ya go-
Here's a dyno showing a port-matched LS2 vs FAST 90, then the same ported LS2 vs TPIS 90mm LS6. CLICK HERE
Difference between the TPIS 90 & FAST 90= 4hp & 2ft/lbs
These results may or may not be typical, so you can make up your own mind. As for me, I'm planning on going with the 90mm LS6 & save that extra $600.
Old Sep 30, 2008 | 07:47 PM
JBIRD02's Avatar
TTT......
still hoping someone w/ a 90mm LS6 will chime in
Old Sep 30, 2008 | 08:47 PM
NJ 2002 Z28's Avatar
You guys should do a search this subject has come up about 4 times in the last 6 weeks...
I have the TPIS 90mm t.b. and Modified Intake I am very happy with it
I am also past the Rwhp that one link claims only a Fast intake car can pass and I still have Cats on my car...
Could I have made more power with a Fast set-up
Probably..
But I didnt spend $1400
Old Sep 30, 2008 | 09:29 PM
JBIRD02's Avatar
Yeah, I've seen them, but was hoping someone might have something to back up Lingenfelters dyno results other than sotp gains.
