Doing it Yourself Port and PolishThrottle body TIPS
Old Sep 10, 2003 | 03:00 PM
ChazLS12002's Avatar
Default Doing it Yourself Port and PolishThrottle body TIPS
This coming weekend Im gonna port and polish my throttle body, anyone have any tips for me?
Old Sep 10, 2003 | 04:44 PM
Colonel's Avatar
Default Re: Ported Throttle body TIPS
Be sure not to grind where the blade meets the housing.
Old Sep 11, 2003 | 11:18 AM
Thanks WILL DO! Anyone else?
Old Sep 11, 2003 | 01:25 PM
TaTommyWS6's Avatar
I made the IAC hole wider than recommended in most of the writeups. My car would not idle well until I opened it up more. (The IAC count was high, but not enough air was making it through)
I used aluminum expoxy for fill. Sorry the pic is so big!
Old Sep 11, 2003 | 03:28 PM
Black Z/28's Avatar
Has anyone tried this:
I cut some brass tubes and layed them in the old holes. I was able to easily position the tubes at the propper angle and I didn't have to go back and re-drill. I Cut the end of each tube at the same bevel (angle) as the inside of the throttle body to get an initial close fit. Then Epoxy, of course, took care of the rest.
The porting part of the job was a pain and took longer than I thought but it was worth it. And I still idle perfect.
Old Sep 11, 2003 | 03:46 PM
MIGHTYMOUSE's Avatar
here's mine, i canned the pcv and coolant tubes since i don't use them.. and filled it with epoxy putty.. same kind i used in the idle control area.
the port blend on this and the shaft machining was done by are, as well as the throttle stop grind to ensure 100% opening.
while at it i put a little bling on it too.. i used rustoleum hammer finish.. very tough stuff.
http://community.webshots.com/photo/...87705163LffSgk
http://community.webshots.com/photo/...87705187SFZSyF
http://community.webshots.com/photo/...87705206QUgHWe
http://community.webshots.com/photo/...87705212uJDsAM
