These headers look OK?
Old Oct 3, 2008 | 03:36 PM
trey1010's Avatar
Default These headers look OK?
Hey guys, I was just wondering if you all thinks these headers look good? are the measurements big enough? thanks!
1 3/4" x 3" Full stainless steel header.
Old Oct 3, 2008 | 04:48 PM
krazy4's Avatar
Measurements are good. That is basically what every other header is.
Those are good budget headers with a few modifications.
You need to cut the collector off the driver side header and re weld it so it sits straight. You also need to grind the K-member on both sides.
Other than that they are supposed to be pretty good.
Old Oct 6, 2008 | 09:05 PM
trey1010's Avatar
thanks! anyone else?
Old Oct 6, 2008 | 09:09 PM
blksbth11's Avatar
I didnt have to do anything on the passengers side. On the drivers side i had to notch the kmember and grind the aluminum tab on the block. I got a custom ypipe made and installed at a local shop for 120.
Old Oct 6, 2008 | 10:38 PM
Pntbll309's Avatar
I didnt have to notch the k member or the tab on the block. They slid right in for me.
Old Oct 6, 2008 | 10:51 PM
Full-Force's Avatar
Alot of haters out there but they are the best bang for the buck.
Old Oct 7, 2008 | 12:03 AM
bayer-z28's Avatar
ARH? My buddy's got a set and he loves em!
Old Oct 7, 2008 | 06:15 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I use only reputable brand headers.
Kooks
Dynatech (love them)
ARH
 Michael S. Palmer
Old Oct 7, 2008 | 08:16 AM
TheSilverOne's Avatar
they have AIR and EGR hookups
Old Oct 7, 2008 | 09:21 AM
Intercooler2's Avatar
You can blank those off or cut and weld. You will need to cut the driver collector and angle. For the $ they can't be touched.
Old Oct 7, 2008 | 12:04 PM
trey1010's Avatar
Has everyone that has used these headers had to cut the driver collector and angle it??
And thanks everyone for the replys
Old Oct 7, 2008 | 01:08 PM
Justin93's Avatar
they look fairly decent for bargan headers!
Old Oct 8, 2008 | 02:03 PM
MarylandSpeed's Avatar
I am not a big fan of knock off/no name products...no matter how cheap.
Old Oct 8, 2008 | 03:14 PM
12secSS's Avatar
So bang for the buck means initial cost is less, but you need to notch your K-member and block, as well as cut and re-weld the collector? I will pay extra for not having to do that with my Hookers (or any other quality, non-low balling supplier).
Headers look good, but if they require that much work to fit them in, I would say pass.
Old Oct 9, 2008 | 12:13 AM
BrokenWs6's Avatar
Can't tell you ya' or nay' because it's not allowed since they aren't a sponsor, but I have them and it takes slight modding to make them fit. I had my driver's side collector cut and dropped 1/4", the air/egr fittings DO NOT line up (mine are deleted so I had them plug welded, but I do know someone who made them work with little effort), and on mine I had to do some slight k-member grinding.
I will say that I am happy with my set.
Old Oct 9, 2008 | 09:38 AM
INMY01TA's Avatar
Well these are not the "XS headers" that used to be on Ebay, not sure if everyone in this thread realizes this but these are copies of those. I have the ole XS headers and did not have to cut the drivers side collector. I did dremel the k member on the drivers side some but no big deal.
Old Oct 9, 2008 | 10:33 AM
BrokenWs6's Avatar
Friend of mine bought a set a week after I did, and he didn't touch the collector, and it never hits the floorboard, so there definately is some inconsistancy in them. Maybe a bad jig...? I was pleased for the $$$, but if I had a big budget for headers, I would have gone with Kooks lol.
Old Oct 9, 2008 | 11:10 AM
INMY01TA's Avatar
Well my driverside collector definaetely points up as you can see from the pic below but it never hits the floor of the car. I think the problem is people try and use either aftermarket y pipes or the y pipe XS/lpp provided (which has no drop after the collector) and that would hit the floor board. If the y pipe has an "s" bend or drop after the collector I don't se it as being a problem. Pic of my custom y below.
Old Oct 9, 2008 | 11:24 AM
I tend to agree with last poster. If you run V-bands like me you will need to cut that side so the clamp doesn't hit. No big deal really.
Old Oct 9, 2008 | 11:42 AM
69chvelle's Avatar
Not sure if these are the ebay/XS longtubes, but the ones in my old camaro went in without a problem.
