relocated battery, installed kill switch, battery voltage lower then normal!!
Old Dec 16, 2008 | 12:49 AM
3fingas's Avatar
Originally Posted by themack56
will do, the problem was that, i also installed a amp relay. So that when i kill the battery, the alternator would die as well. What i didnt know is that the amp relay draws current even when the car is off. So when im not at the track it has to be disconected!!
So tie in the relay neg through an ignition controlled relay. What happened with the gauge dropping?
