Heeeelp!
Old Oct 5, 2008 | 07:06 PM
mattamaya91's Avatar
Question Heeeelp!
can anyone tell me if a ls1 engine will bolt into a 95 trans am, and be compatible, if so i know the computer will have to be changed out but what else?
Old Oct 5, 2008 | 07:16 PM
ddcarter's Avatar
The A/C lines are different. The front crossmember is different. You will need to repin the in car harness. I was going to do this a few years ago and did not want to change so much stuff. I will post more as I remember what else is different. It can be done just alot of parts gathering and/or modifying.
Old Oct 5, 2008 | 08:30 PM
WYATT318MOPAR's Avatar
k-member, under hood harness & pcm, fuel line extensions, motor mounts, headers, all front accessories....As for the trans I would just run an old school auto 350/400 turbo or the six speed if you already have one in the car you got..That should get you started..
