Header install
Old Sep 11, 2003 | 05:14 PM
99blackhawk's Avatar
Default Header install
I've read everything I can find about lt header install tips. But I can't find a good write up on the project start to finish (such as those found on ls1howto.com on other projects). Please help me find good directions hopefully with pics. Thank You
'99 Firehawk, M6, TSP lid, ported & descreened MAF, Bellows, Ported TB, NGK TR 55's, !CAGS, egr mod, free ram air, K&N filter, Mobile 1, TB bypass, Cam & headers to come soon
Old Sep 12, 2003 | 10:17 AM
blk~2000~Z28's Avatar
Default Re: Header install
LS-1 how to links
I searched through all of these and eventually I found one that I was happy with and used that one. It was a write-up on SLP headers and mine are Hooker but I was still able to use it even though they used jack stands and I used a lift. There are definelty sites in there that should help. Also the headers came with the basic directions and in the end that was all I needed to complete this type of install.
Old Sep 12, 2003 | 01:25 PM
Jorday's Avatar
which headers are they?
Old Sep 12, 2003 | 02:21 PM
They will be pacesetters
Old Sep 12, 2003 | 04:36 PM
DARK AGE 53's Avatar
One little tip, stuff a shop rag down into the motor mount opening before you start to remove any bolts. If you don't and you drop a bolt or plug down there you'll understand why you should have.
Al
