How to change pushrods?
Old Feb 11, 2003 | 12:54 AM
BRIAN98Z28's Avatar
Default How to change pushrods?
I guess Im going ot yank the pushrods out and replace them because theyre probably bent. Ive never done this before, dont think ill have a problem, just never done it before. Is there any good install/fix it guides on how to do this?
brian
Old Feb 11, 2003 | 01:00 AM
DERTY's Avatar
The Bull
Default Re: How to change pushrods?
1) Remove coil packs
2) Remove valve covers
3) Remove rockers
4) Replace pushrods
5) Install and tighten rockers to 22 lb-ft
6) If you can, cycle the valve train and then check to 22 lb-ft again (look at unplugging the fuel injector wires so that you don't spray fuel into the cylinders when you do this)
7) Reinstall valve covers and coil packs
Maybe a two hour job tops. I have my head cam install photos on my website, look at JmX's install guide ( LS1HowTo.com as well. Just do the steps up to the push rod removal that makes sense.
Old Feb 11, 2003 | 08:17 AM
BRIAN98Z28's Avatar
thanx derty
