trying to build oil pressure on new motor
Ok guys, Im finishing up my v6 to v8 swap, its a brand new forged 347, new heads, new cam, everything.
Here is what WASNT hooked up;
low oil level sensor
iac
tps
ac line
jumper wire to make all 8 cylinders fire instead of 4.
I pulled the fuel pump fuse, and just wanted to see if they motor would attempt to crank, and try and build a little pil pressure. Car tried to crank everytime, but oil pressure never moved off of 0. Would any of the following cause this, or will i see ANY oil pressure doing this?
iac
tps
ac line
sometimes its a SOB getting oil pressure, esp if you didnt pack the pump with grease or thick oil-i had to overfill mine, jack up the rear to try and let oil run into the pump, finally got pressure
