Advancing/Retarding cam effect P to V clearances?
408 stroker
LS1 heads w/ 2.02-1.6 valves
10:1 compression
through an A4 trans.
Ideally, I'd like to WOT shift just shy of 6000rpms (5500-5800). So if you ran a cam like a 232/240 in that motor, I'd assume you'd have WOT shift points of 6400+, not what I am looking for.
If the cam was advanced around 4* wouldn't that bring the powerband down some?
Would advancing the cam have any determination of piston to valve issues?
Thanks!
Also, the tighter LSA's of like a 110 or 112 have sharper power drop offs and power peaks at lower levels?
So the advancing doesn't really effect the power band too much, well I though it would have been more significant that that.
Thanks!
Advancing a cam will bring the intake closer and the exhaust slightly further from the piston during the overlap period.
Jason
