oil problems
Old Oct 18, 2008 | 10:08 PM
JuicedVette381's Avatar
Exclamation oil problems
i just installed a set of heads and a cam in my 2000 vette. After the first start up the oil pressure dropped from 25 psi to 8 psi! What could this be? i know i installed the O-ring correctly and it is a brand new Performance high volume GM oil pump. What else could it be? my car also went into low power mode?
Old Oct 18, 2008 | 10:15 PM
y2kc5's Avatar
Its the o ring or the tube im betting on the o ring
Old Oct 21, 2008 | 10:52 PM
Exclamation Update!!!!!
Pulled The Engine Back Apart And Checked The Oil Pump To Find Out That The O Ring Was Torn!!!! Changed It Out And Started The Car Instant 45 Psi!!!
Old Oct 21, 2008 | 10:59 PM
y2kc5's Avatar
good to hear man
Old Oct 22, 2008 | 12:59 PM
LSX.monte's Avatar
good thing you found out!
