strange noise from top of motor
Old Oct 20, 2008 | 09:06 PM
dubrado's Avatar
Default strange noise from top of motor
Sounds like a squeak. Not a belt though. It comes from the top of the motor.
It happens on cold starts, but quiets down quite a bit once the motor gets up to temperature. It is not very noticable at all when driving around...BUT if I romp on the car and come to a stop and listen, the squeak noise is back. It'll linger for a minute or so and then quiet down again.
Not sure what is going on....I know that 2 of my cylinders are slightly down on compression, more than what is acceptable but not dead and doesn't smoke really. Unless I'm on it.
Any guesses on what it might be?
I tried pulling the oil cap off to see if it was crankcase pressure venting out but that didn't help out either.
thanks in advance
Old Oct 20, 2008 | 10:29 PM
youguessit's Avatar
Take your belt off and spin your pulleys. If they make any slight noise they can intermitently lock up and let go causeing a unusual sqeel in the belt. It is usually the idler pulleys both ac and main drive. They go bad like its going out of style.
Old Oct 21, 2008 | 02:34 PM
dubrado's Avatar
It's coming from inside the block or manifold, not from the front of the motor where the belts are.
