Fel Pro gasket part numbers?
Old Sep 14, 2003 | 10:12 PM
2001CamaroGuy's Avatar
Default Fel Pro gasket part numbers?
I'm trying to find all the part numbers (and bore sizes) for the Fel Pro gaskets for LS1s.
Does anyone have this info or a link to this info?
Old Sep 14, 2003 | 11:15 PM
Linear Velocity's Avatar
Default Re: Fel Pro gasket part numbers?
I know that for a 4.125" bore it's 1041, but other than I don't know.
Old Sep 15, 2003 | 08:31 AM
Tin Indian's Avatar
Just my opinion, but I still think the factory graphite head gaskets do the best job at sealing.
This is from SDPC (our sponsor) > > > > > > > > > over there > >
This head gasket kit for 1997-2001 LS1 / LS6 engines from GM Performance Parts contains a [pair] of head gaskets. Composition OEM replacement gaskets for 5.7L engines. Contains one LH and one RH gasket. Approximate compressed gasket thickness is 0.056"
Price: $34.95
Part# 12498543
Old Sep 15, 2003 | 11:31 AM
Tin indian, I think camaroguy is building a big bore, in that case I think the Fel Pro's would do the best job.
Old Sep 15, 2003 | 12:38 PM
eventually (next year to year and a half) I want to do a big bore motor.....
but when winter brake rolls around, I am thinking of pulling the heads on my current motor to check things out, possibly flycut the pistons (with the Isky tool), and install a larger cam (already own) to hold me over till I can make some REAL hp.....when I do this I want to put the lower thickness FelPro gasket on to bump the compression up some more (someone said its good for 9cc's or .3 CR rise)....
