Anybody dynoed in cold weather? How does it effect it?
What did you notice?
Was your SAE corrected power about the same? ? (assuming you dynoed before in different weather)
Was you’re A/F ratio effected by much? or at all?
Thanks. <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
<small>[ February 11, 2003, 11:12 AM: Message edited by: EuG ]</small>
So you’re saying you saw some KR that you usually don’t see? Is that right?
Did you’re A/F change at all?
Thanks again! <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Did you’re A/F change at all?</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It was running just a hair leaner but what was strange is that I was about 20+ RWHP down and I decided to reflash the PCM with the exact same program that it was already running and I immediately picked up ~13 RWHP....go figure!
Perhaps computer learned something <img src="http://www.agrnet.com:8888/Pictures/Images/Smilies/Dunno.gif" alt=" - " />
Did you have any KR at that point (after reflash)?
If you were only within 7rwHP and possibly had some KR that you don’t normally have then I think we could assume that corrected numbers are pretty accurate regardless of the weather.
What do you think?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes, it was closer to nominal but still down a bit because the timing still saw about 2.5° KR
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Perhaps computer learned something. Did you have any KR at that point (after reflash)?
</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I got a little less KR than before the reflash (was about 3.5° before and 2.5° after) but it also ran a bit leaner....about 13:1 A/F instead of 12:8 before the reflash which made no sense to me. I suspect that the leaner A/F got me more power back than the less KR but who knows at this point.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">I think we could assume that corrected numbers are pretty accurate regardless of the weather</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">At this point I would say you're probably right although I personally believe that for us folks living north that Std Corrected numbers (rather than SAE) are a better number to use since the weather conditions better reflect reality (I believe it is ~68° temp plus a higher level of humidity).
