safe rev limit on forged ls6?
Old Oct 24, 2008 | 06:10 PM
chris-m's Avatar
Default safe rev limit on forged ls6?
anyone like to advise what the likely safe max rpm would be on my new shortmotor once complete and run in properly? its a new ls6 block, 6l GM crank and wiseco pistons/carrilo rods from WRE.
valvetrain is beehive springs, hardened pushrods, comp cam retainers, and a mild 220/220 111lsa cam.
i expect the cam to peak out at 6200-6300rpm or so anyway but what would the engine take safely/realistically for track use (not drag). oiling is ARE dry sump and a melling pump.
i'm awaiting an reply from WRE to the same question but nothing back yet.
Old Oct 24, 2008 | 07:35 PM
DONAIMIAN's Avatar
If its going to see the road course I wouldn't rev it past 6k. For the street it shouldn't need to go over 6500.
Old Oct 26, 2008 | 06:17 PM
chris-m's Avatar
thanks
Old Oct 27, 2008 | 05:37 PM
black_z's Avatar
Should easily do 7000 if the valvetrain geometry is correct. If the cam holds power to 7000 is another story.
Old Oct 27, 2008 | 06:09 PM
chris-m's Avatar
think the cam will be all done by 6400rpm. i missed a few shifts on my old engine with rev limit at 6500rpm and i did have a bottom end failure (stock engine) so hoping the new setup holds.
