Elliotts Port Works
Old Oct 26, 2008 | 02:02 AM
LavaRock's Avatar
Default Elliotts Port Works
Anyone have the Elliotts Port Works head & cam combo in their car? Any comments on it's performance?
LS1-LE2
These heads are about 10 RWHP/RWTQ over the LE1 heads due to the larger Ferrea 2.02/1.60 valves allowing larger measurements in other areas of the port. There will be less piston to valve clearance with these heads due to the larger diameter valve and thicker valve margin.
The LS1 LE2 heads consist of:
Patriot Gold Dbl springs, Ti retainers, locks and locators
custom valve job
mill, cleaning and assembly
flow about 305/220
ready to bolt on
Old Oct 26, 2008 | 03:32 AM
Speed Density's Avatar
hashtagBMW
Lots of LT1 guys run LE stuff, it seems to work pretty darn well. I would imagine his port work is just as good on LS stuff.
Tony.
Old Oct 26, 2008 | 07:33 AM
Shawn MacAnanny's Avatar
I talked to Lloyd for a while about his head and cam packages a long time ago when i had my other LT1. He is extremely helpful and i had no idea he did LS1s. I will definately be going with his heads now. Whats his website?
Old Oct 26, 2008 | 10:09 AM
LavaRock's Avatar
http://www.elliottsportworks.com/ls1.html
He seems to be well known amongst the LT1 crowd, but I've not heard anything about his LS1 stuff?
Old Oct 26, 2008 | 10:13 AM
I'll definately be getting his heads! If Lloyd put his name on them they MUST be good.
Old Oct 26, 2008 | 10:56 AM
daniel6718's Avatar
i talked to him about it,...he said he has jsut as nasty ls1 stuff but nobody is willing to flycut the pictons to stick a real cam in there so they get a baby cam and not too many see great results...if your willing to listen and do everything he says youll have a badass setup
Old Oct 26, 2008 | 12:58 PM
black6spdz's Avatar
i had a 385 LT1 that made 460 rwhp with his LE3 set up and ported intake. The car was full weight and trapped a best of 122mph when it had true duals on it. Overall i was very satisfied with his working and have been thinking pf using him again for my LS1
Scott
Old Oct 26, 2008 | 08:13 PM
LavaRock's Avatar
Any LS1 guys running these heads?
 Michael S. Palmer
Old Oct 26, 2008 | 10:09 PM
AutomagicLS1's Avatar
I have le2 heads on my car and a bauer cam on my car and love it
Old Oct 27, 2008 | 03:24 PM
LavaRock's Avatar
Do you have any numbers on your combo?
Old Oct 19, 2009 | 06:04 PM
ryle's Avatar
I know this is pretty much a dead thread, but thought I'd bring it back because I'm thinking about it and the question didn't really get answered.
Old Oct 20, 2009 | 08:52 PM
I have a LE2 setup. last time it was ever at a dyno it made 414 on a junk tune, spinning to 6,000 and a slipping tranny (auto)
Old Oct 20, 2009 | 11:18 PM
02*C5's Avatar
Here is one of his combos. The combo was great the guy who ended putting it together was a dumb ***.
http://www.youtube.com/watch?v=4R5k1p0mvmM
232/238 600/600 109 LSA Lloyd Elliot 241 stage 2 heads 2.02 intake 1.60 exhaust,(305@600 217@600) 11.5 -1 compression The guy is really a genius and I would put him against any one.
Old Oct 21, 2009 | 08:17 PM
Here is my car with a le2 setup. cam is a custom grind 230/240 on a 110
http://www.youtube.com/watch?v=iI7QtQE9AcI
Old Nov 5, 2009 | 12:25 PM
ramdaspadhye's Avatar
Lloyd is a great guy to talk to. I had him spec me a custom cam for my carbed Impala...
