Camshaft Discussion part II
Example cam 230/236 112LSA 108ICL
IVO = ((intake duration/2)-ICL)
Ex: ((230/2)-108)= 7 BTDC (negatives indicate ATDC)
IVC = ((-IVO) + intake duration - 180)
Ex: ((-7) + 230 - 180) = 43 ABDC
ECL = ((2 * LSA) - ICL)
Ex: ((2 * 112) - 108) = 116
EVC = ((exhaust duration / 2)- ECL)
Ex: ((236 / 2) - 116) = 2 ATDC (negative indicates BTDC)
EVO = ((-EVC) + exhaust duration - 180)
Ex: ((-2) +236 - 180) = 54 BBDC
Overlap = ((intake duration + exhaust duration)/2) - (2 * LSA)
Ex: ((230+236)/2) - (2 * 112) = 9
Here is the origianl quote on calculating VE.
Ok, now this is my understanding of things. There are four timing parameters that define how your engine will operate. These are intake valve opening (IVO), intake valve closing (IVC), exhaust valve opening (EVO) and exhaust valve closing (EVC). It is relatively easy to derive these parameters from the specs supplied by camshaft vendors (lobe center angle (LCA), intake centerline (IC), intake duration (ID), and exhaust duration (ED)) assuming all these parameters are specified.
IVO = ID/2 – IC
IVC = ID – IVO – 180
EVO = ED – EVC – 180
EVC = ED/2 – 2*LCA – IC
But, thanks for adding the calculation for Exhaust Centerline and overlap. I am putting all this into spreadsheet for everyone to use.
Quick and Dirty VE calculator Spreadsheet
BYBYC5, it looks like you got you IVC and EVO numbers transposed. If that's the case your VE's fall in line as well.
These give me my VE's for a particular setup.
From there it's just a matter of choosing the right lobes. The LSA & ICL are just calculations....just a byproduct of the VE's I choose if you want to look at it like that.
As I said before I choose the lobes based on the flow charateristics of the motor. Intake to exhaust ratio with stub pipe on the exhaust & intake on the heads, whether boost or N2O is involved, racewieght, gearing, etc, etc.
Nitrous is probably one of the bigger questions. Do you tend to up the exhaust side and run a wider LSA when selecting nitrous cams. The conventional school of thought is to go htis route on nitrous cams. I wondered if you concur with this.
*interesting side note*
For best ET/MPH in the 1/4 one should setup their gearing/tire package to end the 1/4 mile just past peak HP.
No real formula for this.... Really depends on the combo & what the owner wants out of it as to what VE's are best. Just gotta know what works with what & why....
Every motor is different. What works well in one application may be totally wrong in another.
Too many variables to post all the little things like this that go into designing the correct profile. This is where an experienced Pro is needed.
When you think about it the main difference between any 2 engines is intake design. I mean, head flow is head flow. The valves are all in generally the same place & at nearly the same angle. Same combustion chamber design for the most part. Longtube headers are all basically the same. Bore & stroke can vary, but not to any drastic extent as to change the fundamentals of a motor. So a lot of the same technics in making power can be used.
I favor reverse-splits on all EFI motors. Hell, from the factory the 4.6 mustangs come with reverse-splits (192/184 114LSA). HP per cube on this motor is not bad at all.
On juiced motors I do fatten up the exhaust lobe a bit. Not to the extent others do as there's really no need unless a larger shot it used (over 150wet). With the added cylinder pressure in the combustion process there is higher velocity during the exhaust stroke....& therefore more flow. I don't automatically add 8 degrees of exhaust duration if that's what you're asking. It depends on the shot used & rest of the combo as to how much intake or exhaust bias to use.
For instance, with a stock LS1 spraying a 200 shot what I generally do is have the ramprates of the lobes the same. But certain applications I may use a softer ramp on the intake....or a reverse-split at .050, but a standard split at .200. There's are so many different combinations of lobes that will perform differently in any given combo. As for LSA with juice...sure I may increase it a bit, but I'd probably use larger lobes too. I generally don't decrease the overlap much with an N2O cam....but again, depends on the combo. A motor that is to pass smog can only have so much overlap anyway...so why decrease it if their using a shot. No need....there's hardly any overlap in the profile anyway. Raw N2O isn't gonna shot out the tailpipes on a setup like this. Now, larger profiles that want max power N/A & use the occassional shot I may or may not decrease the overlap. Depends on the customer needs & the combo....
I really don't mean to talk in circles here guys. But just about every factor in designing a bumpstick is combo/customer specific.
For my cams I shoot for -4 to -3 degrees of overlap on the smogable grinds. (once I get emissions figures on a few of these I may put in more, but for now this is safe.) On non-smogables....all the way up to 10 degrees on the stock longblock will fit if placed correclty. More on strokers & pistons with valve reliefs.
The bigger you make a port, the more it flows. That's hardly shocking news. Bolt a sewer pipe onto a flow bench and it will generate terrific flow numbers. So should we use ports as big as sewer pipes on our race cars? The flow bench says we should - the time slip says something completely different.
If airflow were everything, we would all use the longest duration camshafts we could find - after all, more duration means more flow. In fact we know that there is a finite limit to how long the valves can be open before performance suffers. That is because the valve events have to be in harmony with the rest of the engine.
The same principle applies to cylinder heads. Simple airflow capacity should never be the first consideration in evaluating cylinder heads. Characteristics that are far more important include air speed, port cross section, port volume and shape, and the relationship between the size of the throat and the valve seat. If these attributes are wrong, you can work forever on the flow bench and not overcome the fundamental flaws.
One of the things Craig Gallant @ GTP is fantastic at in his cylinder head program is maximizing cylinder head flow with the carefult slection of valves. On a recent set of heads we use ina class where unported heads are required, he picked us up 40 CFM with just the careful selection of valves, and careful selection of valves angles. No porting whatsoever...
Back to my point about combstion chambers. Lets look at the Hemi. The classic Hemi combustion chamber is capable of producing impressive flow figures, but it's not going to make impressive power. Engine technology in all forms of motorsports is converging around smaller, high-efficiency combustion chamber designs. You can see the result in lower brake specific fuel consumption (BSFC) numbers, which indicate improved engine efficiency. Twenty years ago, a racing engine with a .48 BSFC was considered very good; today's competition engines produce BSFC numbers in the neighborhood of .35. This means that a given quantity of fuel is being atomized and burned more effectively to produce more power. A cylinder head's combustion efficiency can't be measured on a flow bench, yet it has a huge impact on performance.
http://www.burnsstainless.com/TechAr...ry/theory.html
They want just as much information about the motor as any custom cam grinder does to help select the best way to get those burned gasses out of a motor. The concept that maximum power is obtained by zero pressure in the exhaust is only partially true. There should be absolutely no back-pressure from the collector rearward, but the diameter of the system beginning with the exhaust valve is a compromise. The highest efficiency for the system requires a minimum speed for good exhaust gas velocity to insure that gas does not "back up" into the chamber during overlap at low engine speeds, and that the "suction" (negative pressure pulse) effect of a resonant (tuned length) and/or collector (overlapping exhaust pulses) system is optimized.
To predict what primary size will be best for a specific motor, you must know where you want the engine to develop peak torque. If the existing torque peak is at bit lower RPM than you prefer (typical in under-cammed or stock motors), it can be "bumped" a bit by increasing the primary diameter. If the torque peak is too high (motor is "peaky", with no range and poor recovery from gear changes), the peak can be adjusted down by using a smaller pipe. A change of 1/8" in the primary diameter will raise or lower the peak torque RPM by 500 or so.
This factor slightly overlaps the effect of primary pipe length, but the pipe length generally will not change the peak torque or the RPM at which it occurs. A length change has the effect of improving the torque on only 1 side of the peak by "borrowing" it from the other side. A shorter pipe improves the torque after the peak (reduces it at lower RPM), preventing the curve from flattening out so quickly as speed increases. A longer pipe extends the torque curve backwards to improve the engine's flexibility, at the expense of after-peak torque. Less stall speed is required, and the motor will pull taller gears; this re-tunes a 4-speed motor for better operation with Torqueflite, etc.
For best effect, the gas speed in the primary tube at the peak torque RPM should be about 240 feet per second. The formula to calculate pipe size is:
Area of Primary Pipe = RPM × Cylinder Size ÷ 88,200
This determines the pipe's cross-sectional area, from which we can calculate the ID. Typical exhaust pipes are 18ga. (wall thickness of .049"), so the OD will be .098" larger. From this we can construct a formula for an 8 cylinder motor, and factor in the 18ga. wall thickness:
Area of Primary Pipe = RPM × Motor Size ÷ 705,600
Pipe ID^2 = RPM × Motor Size ÷ 705,600 ÷ .7854
Pipe ID^2 = RPM × Motor Size ÷ 554,177
ID = (RPM × Motor Size ÷ 554,177)^.5
OD = (RPM × Motor Size ÷ 554,177)^.5 + .098"
Length (in inches) = (CID x 1900) ÷ (rpm x pri.OD^2)
Here is a little chart I dug up. Does it fit in with your theories?
I look at the camshaft as the end of the intake runner & beginning of the exhaust runner.
I really don't know what you're getting at hear, so I'll go ahead & post a cam that will be tested against a known proven LS1 cam.
There'll be dyno, track, & emissions testing on this cam....along with any drivability issues....& any other issues will be noted & compared.
Hammer cam: 222/222 112LSA 108ICL .566/.566
VS
224/222 113LSA 113ICL .581/.566
The exhaust lobe on my cam is the same as the Hammer. the only difference is a larger, more agressive intake lobe & a slightly wider LSA for passing emissions testing....oh & different VE's.
These are both LS1 Comp XE lobes. No tricks on this one.
Specs on the 2 lobes:
222:
.006 - 275
.050 - 222
.200 - 140
224:
.006 - 273
.050 - 224
.200 - 145
Plot the VE's for all these lift points on both cams & you will see exactly what I did. By the theories I've posted in this thread & others you'll should be able to figure out why I moved the VE's the way I did & why I went with a more agressive intake lobe.
Ok, I expanded the quick and dirty VE calculator a bit to do both cams at all three lift points, and compare the deltas.
Quick and Dirty Cam Calculator Spreadsheet
0.006 0.050 0.200
Intake Duration - ID 275 222 140
Exhaust Duration - ED 275 222 140
Lobe Center Angle - LCA (also known as LSA) 112 112 112
Intake Centerline - ICL 108 108 108
Intake Valve opens - IVO 29.5 3 -38 BTDC (- indicates ATDC)
Intake Valve closes - IVC 65.5 39 -2 ABDC
Exhaust Valve Opens - EVO 73.5 47 6 BBDC
Exhaust Valve Closes - EVC 21.5 -5 -46 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 116 116 116
Overlap 51 -2 -84 degrees
0.006 0.050 0.200
Intake Duration - ID 273 224 145
Exhaust Duration - ED 222 222 222
Lobe Center Angle - LCA (also known as LSA) 113 113 113
Intake Centerline - ICL 113 113 113
Intake Valve opens - IVO 23.5 -1 -40.5 BTDC (- indicates ATDC)
Intake Valve closes - IVC 69.5 45 5.5 ABDC
Exhaust Valve Opens - EVO 44 44 44 BBDC
Exhaust Valve Closes - EVC -2 -2 -2 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 113 113 113
Overlap 21.5 -3 -42.5 degrees
0.006 0.050 0.200
IVO delta 6 4 2.5
IVC delta -4 -6 -7.5
EVO delta 29.5 3 -38
EVC delta 23.5 -3 -44
ECL delta 3 3 3
Overlap 29.5 1 -41.5
I'll crunch on it a bit and post up later. You can tell me if I totally have it wrong...
0.006 0.050 0.200
0.006 0.050 0.200
Exhaust Valve Opens - EVO 70.5 44 3 BBDC
Exhaust Valve Closes - EVC 24.5 -2 -43 ATDC (- indicates BTDC)
Overlap 48 -3 -83.5 degrees
0.006 0.050 0.200
IVO delta 6 4 2.5
EVO delta 3 3 3
EVC delta -3 -3 -3
ECL delta 3 3 3
Overlap 3 1 -0.5
Is that better?
Ok, so 93Pony. You:
Select EVO based on IVC, then overlap, then EVC and IVO...
So, looking at your cams:
IVC/ EVO
45/ 44
47/ 43
49/ 48
50/ 49
The other cams they were compared to:
IVC EVO
39/ 47
41/ 52
44/ 56
There are definitely some trends there, I was just wondering if you wanted to comment on the "why"...
Intake Duration - ID 281 232 153 3726 lobe
Exhaust Duration - ED 289 240 161 3730 lobe
Lobe Center Angle - LCA (also known as LSA) 108 108 108
Intake Centerline - ICL 112 112 112
Intake Valve opens - IVO 28.5 4 -35.5 BTDC (- indicates ATDC)
Intake Valve closes - IVC 72.5 48 8.5 ABDC
Exhaust Valve Opens - EVO 68.5 44 4.5 BBDC
Exhaust Valve Closes - EVC 40.5 16 -23.5 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 104 104 104
Overlap 69 20 -59 degrees
0.006 0.050 0.200
IVO delta 5 5 5
IVC delta -1 -1 -1
EVO delta -1 -1 -1
EVC delta -7 -7 -7
ECL delta 3 3 3
Overlap -2 -2 -2
Anywhere close?
As for your standard split cam using modified VE's. Well....there is now another problem with your VE's. The ovlerap VE's are no where near ideal. So, basically a standard split is a comprimise between IVO/EVC VE's & the IVC/EVO VE's.
Another thing one should note.... ICL plays a factor in intake & exhaust bias. Retard the cam & it becomes less exhaust bias relative to TDC, Advance the cam & it becomes less intake bias relative to TDC.
So, you've made that cam less exhaust bias, but at the sacrafice of the overlap phase.
Is there any real world data that can be offered that will not reveal any "speed secrets" in your cam profiles? Are they for sale? If so where can we purchase one?
Thanks in advance,
Bob
But the concepts have been proven time & time again. On both LS1's & Ford's....& not only by me.
I sell LS1 customs for $450 shipped.
Valve events comparison:
Your cam:
IVO: 2 BTDC
IVC: 50 ABDC
EVO: 49 BBDC
EVC: 1 ATDC
That cam:
IVO: 5 BTDC
IVC: 41 ABDC
EVO: 52 BBDC
EVC: 0 (TDC)
You'll be going from a cam that is basically 1 degree intake bias to a cam that is 11 degrees exhaust bias relative to the piston at TDC. Now, this isn't bad as it has some overlap & the intake will be open enough during the overlap cycle to cut down on the exhaust reversion.
If you're looking for more power, this is not the cam for you...it will not make near the power your current cam is capable of. The 10 degrees less intake duration at .200 is gonna take quite a bit of power away. + the exhaust is acutally smaller by 3 degrees at .200 too....so overall the cam will flow significantly less & not have near as steady an idle as you have now.
IVC: 50 ABDC vs IVC: 41 ABDC = 9 degrees later (ABDC meaning After Bottom Dead Ceter)
EVO: 49 BBDC vs EVO: 52 BBDC = 3 degrees later (BBDC means Before Bottom Dead Center)
You also favor a lot of overlap, and in many cases your cams have a lot more than many other cams. With many of the cams on the market today tighter LSAs reduce drivability, raise emissions, and play havoc with untuned computers. One of the things you alluded to was that you feel it is not so much the cams themselves as where the VE's are placed, and that you could use a bigger cam if the valve events were a bit more ideal. (Correct me if any of this is wrong).
One things in racing engines that has been learned that is low-lift flow is relatively unimportant. In a racing engine: From the point when the valve first moves off its seat until it reaches mid-lift, the piston is either going the wrong way (that is, it is rising in the cylinder) or it's parked near TDC. The piston doesn't begin to move away from the combustion chamber with enough velocity to lower the pressure in the cylinder until the valve is nearly halfway open. Consequently it is high-lift flow that really matters in a drag racing engine. Now, thats racing... We're talking about street motors. So, your theories may or may not be based on that.
I think low to mid lift flow in the head is important to assist in cylinder filling, and blowdown. Also that port velocity is important. I agree to a certain extent that huge ports with good flow are not nearly as important as small ports with good flow. But I don't necessarily agree with you about the idea of stock heads being better than ported ones. I will be interested to see wha thte AFR heads do with a intake port as small as stock with 40CFM more flow than a ported head with 20cc more volume.
I guess one of the things I am wondering is if you are so concerned with EVO and IVC specifically, or where it put the valve later on in the intake and exhaust cycle.
Ok, like I said before, I know you aren't a fan of standard splits. And I know you don't like a ton of advance ground into a cam. So, I'll change things up a bit. Lets do a G5X2 clone but in a reverse split. We'll keep the intake the same and simply put on a smaller exhaust.
Ok, intake lobe first.
# 3726 lobe 232@.050 / 153@.200 / 281 Advertised. .595 lift
Now, for the exhaust side. Looking at your format, I am torn between 3 lobes
# 3724 lobe 228@.050 / 149@.200 / 277 Advertised .588 lift
# 3718 lobe 230@.050 / 147@.200 / 283 Advertised .573 lift
# 3725 lobe 230@.050 / 151@.200 / 279 Advertised .592 lift
Ok, so lets look at all three. Now let me preference this first. Theis is a clone or a SWAG at the G5X2 specs. THESE ARE NOT Lou's specs... I don't have Lou's specs in my back pocket. What I am assuming her eis if you call comp and you order the lobes that are similar to the G5X2 lobes, and you order it on a 112, comp will grinf it with 4 degrees in it unless you ask for something else specifically.
So, with that in mind, lets look at what I come up with....
0.006 0.050 0.200
Intake Duration - ID 285 236 157 3728 lobe
Exhaust Duration - ED 281 232 153 3726 lobe
Intake Valve opens - IVO 34.5 10 -29.5 BTDC (- indicates ATDC)
Intake Valve closes - IVC 70.5 46 6.5 ABDC
Exhaust Valve Opens - EVO 76.5 52 12.5 BBDC
Exhaust Valve Closes - EVC 24.5 0 -39.5 ATDC (- indicates BTDC)
Overlap 59 10 -69 degrees
0.006 0.050 0.200
Exhaust Duration - ED 277 228 147 3724 lobe
Intake Valve opens - IVO 32.5 8 -31.5 BTDC (- indicates ATDC)
Intake Valve closes - IVC 68.5 44 4.5 ABDC
Exhaust Valve Opens - EVO 66.5 42 1.5 BBDC
Exhaust Valve Closes - EVC 30.5 6 -34.5 ATDC (- indicates BTDC)
Exhaust Centerline - ECL 108 108 108
Overlap 63 14 -66 degrees
0.006 0.050 0.200
IVO delta 2 2 2
IVC delta 2 2 2
EVO delta 10 10 11
EVC delta -6 -6 -5
ECL delta 8 8 8
Overlap -4 -4 -3
Cam # 2
0.006 0.050 0.200
Exhaust Duration - ED 279 230 151 3725 lobe
Exhaust Valve Opens - EVO 67.5 43 3.5 BBDC
Exhaust Valve Closes - EVC 31.5 7 -32.5 ATDC (- indicates BTDC)
Overlap 64 15 -64 degrees
0.006 0.050 0.200
IVO delta 2 2 2
IVC delta 2 2 2
EVO delta 9 9 9
EVC delta -7 -7 -7
ECL delta 8 8 8
Overlap -5 -5 -5
Cam # 3
0.006 0.050 0.200
Exhaust Duration - ED 283 230 147 3718 lobe
Exhaust Valve Opens - EVO 69.5 43 1.5 BBDC
Exhaust Valve Closes - EVC 33.5 7 -34.5 ATDC (- indicates BTDC)
Overlap 66 15 -66 degrees
0.006 0.050 0.200
IVO delta 2 2 2
IVC delta 2 2 2
EVO delta 7 9 11
EVC delta -9 -7 -5
ECL delta 8 8 8
Overlap -7 -5 -3
Ok, this moved the IVC/EVO from 46/52 to 44/43 you gained several degrees more overlap @ .050, etc.... Is this any better?
Not trying to take this too far out of context, so correct me if I am, but this seems like a *far* to general statement.
Take a stock crossfire SBC, a stock LT1, a LT1 with 215RR AFR heads but a 3" exhaust, a supercharged through the cats LS1 - do you really think that they are all going to work best neccecarily with a reverse split camshaft?
What I would really like to see is what we are using for metric's here in determining what valve events one is looking for - e.g. take the cross sectional area of an intake port, determine a certain depression due to the rotating assembly configuration, etc.
Your posts are giving me headaches again. But you're on the right track with those lobes you chose. Just have to find the right ones for the right applications.
Funny thing about that cam you quoted from Norcal-LS1. The guy put in a MUCH larger cam (231/237 112LSA) & an M6 over the A4 & ran much slower at the track. He's told me recently he's buying his old cam back.
ChrisB,
The VE's are based on Comps specs of the lobes. It does not matter if they are asymmetrical or not.
I do Favor reverse-splits on EFI motor. But that does not mean I use them on every application...nor does it mean they'll work best on every EFI motor. Just that I favor them. & yes, it is a VERY general statement.
Every application is different.
