lifter replacement problem
Old Nov 3, 2008 | 09:14 AM
bigboy t/a's Avatar
Exclamation lifter replacement problem
how hard is it to change a lifter on a 99 t/a?
how excactly would i know if a lifter failed
Old Nov 3, 2008 | 09:27 AM
5.3LJimmy's Avatar
You have to remove the cylinder heads to replace the lifters. Usually a failed lifter will make a constant loud ticking(if collapsed). If you just have a ticking noise you can try running a can of seafoam in your oil for about 20 miles then change the oil. If that doesn't help the next step would be to make sure you don't have any bent pushrods, which will also sound like a collapsed lifter.
Old Nov 3, 2008 | 09:38 AM
bigboy t/a's Avatar
yea its gotten to the point were it is loud
thanks for the info
