LS1 pcv system
Old Nov 3, 2008 | 10:31 AM
kossuth's Avatar
Default LS1 pcv system
Did a search and didn't seem to find what I wanted. Doing a LS1 swap on a older non emissions car and looking to eliminate the PCV system. What would be the proper way to do it? I am using a Edelbrock carb style intake but with fuel rails and a fast 4 bbl type throttle body. I was thinking of putting a breather in the driver's side valve cover. On the passenger side I was debating between actually using a PCV valve in it again and just putting the hose into the bottom of the air cleaner or just venting it. Please post pros/cons or the proper way to do it. Other than the intake motor is bone stock. Yeah I know intake and TB are overkill but it's what the customer wanted.
Old Nov 3, 2008 | 10:59 AM
sroach20's Avatar
vacuum pump or use breathers and change your oil all the time.
