cam installation
Old Nov 7, 2008 | 09:37 PM
GM WORLD CLASS's Avatar
Default cam installation
when yall do your cams in ls1 f-body do you replace bearings? i would like to do a cam swap w/out pullin the engine, but if its common for bearing to be damaged and need replacing then i guess ill just pull it. my oil pressure is always good so hopefully the bearings would be ok. im not sure if i could get enough space in the front with the engine to pull the cam anyway in but i think its possible.
Old Nov 7, 2008 | 10:03 PM
sroach20's Avatar
just dont rip out the old one and jam the new one in. if you are carefull, everything will be cool.
Old Nov 7, 2008 | 10:07 PM
94'BLKBRD's Avatar
Patience is your friend
Old Nov 7, 2008 | 11:24 PM
ABQ99TA's Avatar
http://www.ls1howto.com/ This will be your friend.
