Solvent to clean head gasket off block
Old Sep 18, 2003 | 09:46 PM
y-man's Avatar
Default Solvent to clean head gasket off block
Is there any type of solvent like isopropyl alcohol or something like that I can use to make sure I get all the old head gasket material off the block? I've scrapped most of it off with a plastic scraper and/or my finger nail, but would like to make sure it's as clean as possible. I'm very hesitant to use a razor blade for fear of nicking the block.
Thanks for the help!
Matt
Old Sep 18, 2003 | 09:58 PM
Dave Carney's Avatar
Default Re: Solvent to clean head gasket off block
Go to autozone or similar and pick up a spray can of gasket remover, spray it on, let it soak an hour or two, then scrape. Works quite well, but you may have to apply it twice depending on how much material you are dealing with.
dc
Old Sep 18, 2003 | 11:34 PM
JPR's Avatar
JPR
The best type is CRC spary lube IMO, works like a charm and won't strip the oil off the cyl walls. Don't be scared to razor the block.
Joe.
Old Sep 19, 2003 | 09:59 AM
BergerMan's Avatar
Just use BrakeClean on it and it will be fine. You do not have to get every bit of graphite off the surface. Just scrape it with a razor blade and wipe it down with BrakeClean.
Old Sep 19, 2003 | 10:34 AM
2xLS1's Avatar
WD-40 and a red Scotch Brite pad works great on the old gasket residue and the carbon on the pistons as well.
