whats my comp ratio? -32cc
Old Nov 9, 2008 | 01:55 PM
chevellepowered's Avatar
Default whats my comp ratio? -32cc
3.622 stroke,stock, 6.125 rods, -32cc pistons. 853 ls1 heads think they are 68 cc stock..?,, and a 4.005 bore..i look on here could find a comp ratio chart..thanks..
Old Nov 9, 2008 | 02:15 PM
BackinBlack02SS's Avatar
What gasket are you using and what's your deck?
Old Nov 10, 2008 | 03:47 PM
i dont know what the deck hight is, but i will be using gm mls gasket..i will do some more research on the pistons..
Old Nov 10, 2008 | 03:51 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
The info you've provided, assuming the piston is out of the hole .005", nets you 7.80:1 SCR.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 10, 2008 | 04:14 PM
thanks that was fast.. i found a comp chart ,, it was giving me just about near the same answer as u did.. thanks. dang that is low.. what kinda boost u think i could run on 93 octane?..
Old Nov 10, 2008 | 04:26 PM
That's VERY low. Do you already have these parts? Or are you still shopping. I'd try and get some more compression in it in most cases!
__________________
Old Nov 10, 2008 | 04:28 PM
i already have them.. i think i should get a smaller cc head. to bring my comp up to 8.5/1
Old Nov 10, 2008 | 06:18 PM
I don't know if I would assume how far your pistons are in or out of the hole. Do you know the compression height?
