Ls1 block to l92
Old Nov 9, 2008 | 11:27 PM
Jditlfm's Avatar
Default Ls1 block to l92
I have searched but i couldn't find anyone who just swapped blocks and not the heads. The car is a 2001 trans am and were going to do a 418 aluminum 6.2 based block with ls1 based afr 205 heads fast intake. What covers sensors wont transfer over if i am just basically doing a short block. The engine will have a 24x crank wheel so that's taken care of. Thanks for any help.
Old Nov 10, 2008 | 12:01 AM
njc.corp's Avatar
from memomry the valley cover will need to be the l92 one and the knock sensors off the ls1 cant be used and u will need a loom for the length as the knock stuff is on the side of the blocks-
also the cam sensor will be at the front -so extend that loom too-
i presume u are using the ls1 intake?
if u are not then u will have to extend the map loom towards the front of the car as the map sensor is near the t/b on the later style gm intakes-
hope that helps-
Old Nov 10, 2008 | 09:10 AM
T/AWS666's Avatar
was also wondering the same thing. Heads for an LS1 should bolt right up am I correct? And what sponsors have the conversion kit needed for the swap? (just the L92 block, not the whole motor)
Old Nov 10, 2008 | 10:12 AM
Jon@Texas-Speed's Avatar
We offer a coversion kit for the swap. It will come with the LS2 timing set, (for 24x cam signal), LS3 Valley Cover, LS3 Front Cover w/ Cam Sensor, LS2 Lifter Trays, and Cam Sensor/Knock Sensor Extension Harness. It should have everything you need to convert your LS1 based vehicle to use a LS-2/3 engine. The rest of the parts are interchangeable between all LS based engines. Let me know if you have any questions!
Jon Reynolds
Texas Speed & Performance
Old Nov 10, 2008 | 03:20 PM
T/AWS666's Avatar
so can an LS1 style head (for example afr205) bolt right up to an L92 block? or do you need different heads?
Old Nov 10, 2008 | 03:47 PM
The heads will bolt onto the block without issue.
Old Nov 10, 2008 | 04:17 PM
Jditlfm's Avatar
perfect. thank you.
