l92 head question
Old Nov 11, 2008 | 08:50 PM
ajohn302's Avatar
Default l92 head question
if you use l92 heads you have to use the l92 intake does it fit on a ls1 camaro and everything hook up? it will be on a iron block 6.o thanks john
Old Nov 12, 2008 | 05:56 AM
WKMCD's Avatar
The L92 intake is a truck intake. You'll want to use the L76 intake and you'll need to use the L76 fuel rails unless you have a return style fuel system. It also uses a 90mm TB.
Old Nov 12, 2008 | 10:25 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Like stated above, you'll need to use the L76/LS3 intake to fit under the hood of the Camaro. Also, you'll need an extension harness for your MAP sensor, because this intake has the sensor at the front of the manifold instead of at the rear like your LS1/6 manifold did.
We offer all of these parts at competitive prices. Let us know if we can help!!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 12, 2008 | 03:16 PM
garrettpen's Avatar
I bought a complete intake from GMPP a while back which was a smoking deal for $550, you got the intake LS7 injectors fuel rails sensors and a 90mm throttle body
Old Nov 12, 2008 | 06:02 PM
ajohn302's Avatar
thanks john
Old Nov 12, 2008 | 06:57 PM
Grimes's Avatar
I don't think that l92 heads will work well with the 6.0L bore. Not optimally anyway. have you considered other heads?
Old Nov 21, 2008 | 06:28 PM
jmoody66's Avatar
Default Part numbers
Man hook me up....Ive searched and searched and can find the heads but am unable to find this deal you are talking about...
Old Nov 21, 2008 | 09:20 PM
Gen414's Avatar
Maybe I am missing something here. Maybe you are thinking that the L92 will not work on the LS1 block, maybe??
Old Nov 21, 2008 | 09:24 PM
the_merv's Avatar
The Heads will work on a 6.0l Bore.. I'm running them on a 4.000" Bore without a problem.
The L76 Intake also takes the LS2 Fuel Rails..
