Cam in A4 with stock stall???
Ran fine, but would bog irradically from a stop.
I thought part of it was the tune, but a
New converter fixed the problem.
If I remember correctly: - track times below.
13.2 @ 105 - stock cam/stock stall w/Bolt ons.
13.2 @ 105 - 221/221 cam / stocks stall w/Bolt ons. (always bogged)
12.6 @ 108 - 221/221 cam / 3500 stall w/Bolt ons.
My GF DDs an 02 TA with a 224r, Yank SS3600. And if I hadnt driven the car before the stall, I would not be able to tell it was there just driving around.
It also has one of the big B&M coolers, the one with the fan on it. Even in heavy stop and go traffic on a hot day, I have never seen it go over 190 on the gauge.
However with the cutout closed through the stock catback, it sounds just like stock. You can however get it on a 114 and 116 lobe seperation, it would probably sound very close to stock on one of those LSA.
Yeah, if you stomp on the gas the RPMS shoot up to that area and the car takes off hard, or spins the tires lol. Just driving around like normal though there isnt much of a difference.
but i went through that phase too for like a week when i didnt want to buy a $700 converter. then i got over and realized how much of a bad idea it was,
of course you can run an aftermarket cam with a stock stall, but it would be SO small, i dont really see the gains being worth anywhere near the amount of money you would have to put into it. and even then you are losing some driveablitily, just a bad idea overall.
when you say out of the question, to me, out of the question in this situation means that trans better be infested with mutant cobras that will attack whoever removes the stock stall, otherwise call yank and get this sucker done
Ran it for a year or two and sprayed on it, no problems
Drove just like any other cammed car
Then later put in a stall w/new trans.
to push thru the stock stall even at 800 rpm you will feel the converter trying to push thru
the brakes. It feels like you're holding the brake and gas pedal down at the same time.
