Worked on Motor Today...
Old Nov 17, 2008 | 08:22 PM
S10xGN's Avatar
Default Worked on Motor Today...
Hi All,
Got my new "micropolished" Comp 918's installed, got my (used) TSP Torquer V2 cam installed, got my new double-row Rollmaster timing set installed, checked my PTV clearance and had 0.200" straight up with 0.240" at 10° either side. Did a cold leakdown with no oil in the cyl's (engine has been sitting on the engine stand for 3 yrs!) amd had 91% front cyls. down to 83% rear cyls. No valves leaking, all rings...
Everything went great until I decided to degree the cam. Admittedly, one major snafu was trying to use the 918's to degree with. I'll get some light check springs tomorrow (the check springs I used to see the PTV are too light).
What I saw using the wrong springs was only 0.360" lift at the retainers and all specs were 30° late with the chain installed straight up. Does that sound right? I'm hoping the light springs will bring all specs into their proper range.
Russ
Old Nov 18, 2008 | 07:49 PM
S10xGN's Avatar
Default Cam won't degree right!
Hi again,
OK, I got a light spring installed and (using only #1 intake pushrod) my I.O. is 12° BTDC (instead of the 6° called for). When I rotate the crank until I see 0.050" on closing, my I.C. is 56° ABDC (instead of the 46° called for). Regardless of being 6° advanced, why am I getting 248° duration (instead of 232 called for)?
Before doing anything else, I put the old stock timing set back in and checked it, same results! Next, I retarded the cam 6° and checked it again. Now the I.O. is @ 6° BTDC like the card says, but the I.C. is @ 62° ABDC.
Am I doing this wrong or is my cam mismarked? It's a TSP Torquer V2 which I bought here used (no card). I got with Jason and sent him the serial off the cam and he sent me a card:
________________________________________________
_____________________ __INTAKE_______EXHAUST
Valve Adjustment_________ _HYD___________HYD
Gross Valve Lift__________ _.595___________.598
Duration @ .006 Tappet Lift__281_________ __283
Valve Timing @ .050_______OPEN_________CLOSE
_________________INT:_ _6 BTDC_______46 ABDC
________________EXH:__53 BBDC________1 ATDC
These specs are for cam installed @ 110° intake centerline
Duration @ .050___________232___________234
Lobe Lift________________.3500_______ __.3520
Lobe Separation_________ _113°
Also of note, I'm getting 0.550 lift instead of the 0.595 listed, but that could be some lifter slack...
Any ideas?
Russ
Old Nov 19, 2008 | 07:07 PM
S10xGN's Avatar
OK, I'm a dumba$$! I dug out my old Iskendarian "cam handbook" from 1976 and found that I was checking at the valvestem and NOT the pushrod. Everything came out A-OK, motor's back together now. BTW, that old book has a pic of an Isky beehive valve spring way back then!
Russ
Old Nov 19, 2008 | 07:24 PM
5.3LJimmy's Avatar
Glad you figured it out.
I'm upset because I thought I was the only one that still had that Isky book.
Old Nov 21, 2008 | 07:50 PM
S10xGN's Avatar
Done!
Old Nov 21, 2008 | 08:45 PM
98Camarod's Avatar
Two things, valve covers are bad ***, and thats a pretty intense alternator bracket, looks good
Old Nov 21, 2008 | 08:53 PM
brad8266's Avatar
Carb'd LS1's are sweet.
