oil pump shimming
Old Nov 18, 2008 | 02:54 PM
redemn93's Avatar
Default oil pump shimming
well, i am about to do an oil pump in my car and while reading up on different posts, i saw where some guys are shimming them. i tried doing a search but couldnt quite find what i was looking for. how do i know if i need to shim, how much i would need to shim and where exactly do they get shimmed at? on the pressure side or relief side? i am looking at ls6 pumps. not sure if i am going ported or not. depends what i find. thanks for the info!!
Old Nov 18, 2008 | 03:03 PM
conan's Avatar
Are you talking about shimming it to pump more oil or shimming it to clear a double roller timing chain?
Old Nov 18, 2008 | 07:03 PM
redemn93's Avatar
more oil. i am getting a TSP ported ls6 pump.
Old Nov 19, 2008 | 12:04 AM
conan's Avatar
I have a ported ls6 pump from TSP and i make 60 psi at cold idle, 50psi at hot idle, and 80 psi at WOT. I don't think you will need do any thing to that pump.
Old Nov 19, 2008 | 07:55 AM
redemn93's Avatar
sounds good to me. thanks for the info. i guess its a trial and error type thing to get the pressure you want? how much pressure is too much?
Old Dec 3, 2008 | 08:58 AM
redemn93's Avatar
i have my TSP ported 1s6 pump in. 60 psi cold idle. 38-39 hot idle and 60-65 WOT. i am guessing its lower because i have a stock thermostat? once i get a 160 stat i am guessing it will go up?
Old Dec 3, 2008 | 09:02 AM
conan's Avatar
How many miles are on your engine? The tighter the bearing clearance the more oil pressure you will make. The #'s I gave you were on a brand new engine. So 60-65 psi at hot WOT on a 98 is doing good if you ask me.
Old Dec 3, 2008 | 09:12 AM
redemn93's Avatar
103k miles. i am happy with it. dont get me wrong. its better than is was with the old pump. thanks for your input conan. time for an ls6 manifold now.
Old Dec 3, 2008 | 09:18 AM
conan's Avatar
: No pronblem glad you solved your problem.
