Lifter Help ????
Old Nov 22, 2008 | 08:29 AM
LSXS10's Avatar
Default Lifter Help ????
Hey guys, cant decide on the lifters. The cam is a 239/254 .605/.612 , 114ls. Its in a 370 and im going to spin it around 7k. Im thinking about the LS7 or maybe the CTSV lifters from SDPC. Think its a good choice? thanks in advance....
Old Nov 22, 2008 | 09:05 AM
PREDATOR-Z's Avatar
Yes or just plain Comp Cam 850-16
Old Nov 22, 2008 | 09:16 AM
JPH's Avatar
JPH
"new" stockers should work fine. What year is the block?
Old Nov 22, 2008 | 08:59 PM
LSXS10's Avatar
The block is an 05. I thought about the comps also, Im going to do the LS7's unless the comps are better?????
Old Nov 22, 2008 | 11:23 PM
PREDATOR-Z's Avatar
I've seen both fail, actualyy I've seen all lifters fail. Point is they will both work, my advice is to change holding cups, those are like a gasket, always change them.
Old Nov 23, 2008 | 09:03 AM
JPH's Avatar
JPH
Becareful on newer style LS blocks and LARGE cams, the "oil band" on the lifter might not be correct for the block or work with a HUGE cam, causing oil pressure issues.
Old Nov 23, 2008 | 10:55 AM
99blancoSS's Avatar
If you want a true upgrade to a hi peformance lifter the Morel is a good way to go. BUT they are not cheap!
Old Nov 23, 2008 | 02:11 PM
vsocks1's Avatar
Or easy to get. Apparently they are on national backorder. Have had some on order since end of October and they are telling me December!
Old Nov 23, 2008 | 06:15 PM
black01_WS6's Avatar
I have the ls7 lifters and they seem to work I only replaced them as I have high miles and was in there changing some stuff out.
Old Nov 23, 2008 | 10:08 PM
LSXS10's Avatar
Tell me more on this oil presure problem...Is it due to the location of the oil galley in the block, or is it the oil band on the late model lifters? I havent heard of this. The cam is only .615 lift, think it will be ok? Also i am using new lifter trays and probly the LS7 lifters for the price...
Old Nov 24, 2008 | 05:27 PM
JPH's Avatar
JPH
It's the lifter oil band itself. Like I said, there a cases where a guy uses a 259/267 .644/.644 with a comp #850/crane #10530, etc.. and has an oil pressure issue. That's why there are taller body(long travel lifters) designed for this issue. NOT to many people have run into this yet.
