Ls1 & Lt1 rack/pinion the same??
Old Nov 22, 2008 | 04:28 PM
RyanSws6's Avatar
Default Ls1 & Lt1 rack/pinion the same??
My LS1 rack is leaking bad and I found an LT1 rack. Are they the same?? They look like it. I'd like to confirm before I get it.
Old Nov 22, 2008 | 07:32 PM
noriceinside's Avatar
no they are not. the angle of the input shaft is different and thus the linkage is the wrong length. you may be able to make it work if you get LT1 linkage but that would be dumb. then you have a rag joint to worry about.
Old Nov 22, 2008 | 07:33 PM
wrong forum by the way
Old Nov 22, 2008 | 09:01 PM
RyanSws6's Avatar
Your right I'm so used to posting on this one. Thanks for the info.
