GM Hotcam
Old Nov 25, 2008 | 08:04 AM
texasglock23's Avatar
Default GM Hotcam
I did my own search and have found good and bad things about this cam. However, my goals right now are for performance and sound on a budget. I recently found a hotcam for $150 so I think I may go ahead and scoop it up. What other supporting mods besides springs will I need? Which springs should I go with? LS6, Patriot or other? Of course I will retune after the install.
Also, with such a small cam will I need to do a stall? As of right now I hadn't planned on running a stall. I read that I do not need one, but will only benefit from it.
Old Nov 25, 2008 | 08:06 AM
vettenuts's Avatar
Hotcam has a pretty lumpy idle, I would think it would be a pain without a stall. As for springs, I thought the "kit" came with LS6 springs, which can be had for about $60.
Old Nov 25, 2008 | 08:13 AM
I don't believe the cam is a "kit" for that cheap.
Old Nov 25, 2008 | 08:56 AM
99_Z28's Avatar
Ls6 spring will be fine and you can leave everything else stock, but your going to need a stall...
Old Nov 25, 2008 | 02:54 PM
tpain's Avatar
i got my hotcam installed saturday, i have only driven it twice since then.
it does need a stall, but i think you could get around for a little while with the stock converter, and as far as the driveablity its does ok on the stock tune, runs a little rich right now, and has a little surge to it when coming to a stop.
hopefully i can get my stall installed this week and tuned sometime in the next month.
Old Nov 25, 2008 | 03:07 PM
sidewayz28's Avatar
i think youd be fine on the stock stall.. that cam ISNT that big
Old Nov 25, 2008 | 06:02 PM
tpain's Avatar
stock stall might work, but i would get a stall.
