Holden V8 = LS1 correct?
Old Sep 23, 2003 | 01:52 AM
2001CamaroGuy's Avatar
Default Holden V8 = LS1 correct?
The Holden V8 is the same as the LS1 correct? The reason I ask is that Comp cam makes a solid roller lifter that says:
881-16 Holden V8 "The best and only set available for the Holden. Works in any application."
Diameter = 0.842"
Are these LS1 specific solid lifters? I was told the stock lifter bore is 0.844".
Old Sep 23, 2003 | 01:59 AM
66ImpalaLT1's Avatar
Default Re: Holden V8 = LS1 correct?
Holden had a V8 prior to the LS1, you should probably call Comp Cams to verify.
Old Sep 23, 2003 | 03:08 AM
GTBMad's Avatar
The holden V8 was made in the early 70s in Australia as a replacement to the small block chev. It remained in production till replaced by the LS1 in 1999. Answer to your query completely different motor.
Old Sep 23, 2003 | 01:48 PM
and here I was all excited.....
