Torque specs on head bolts
Old Sep 23, 2003 | 04:13 PM
NSSINR8 U's Avatar
Default Torque specs on head bolts
thanks
Old Sep 23, 2003 | 05:17 PM
jmX's Avatar
jmX
Default Re: Torque specs on head bolts
See sig
Old Sep 24, 2003 | 09:14 AM
robertbartsch's Avatar
...the offical GM torque specs are done per the JMX directions above....they work out to be close to about 75lbs for the long bolts and 65-70-lbs for the two shorter bolts...
Do the tightening in a sequence....
Old Sep 24, 2003 | 09:26 AM
smokinHawk's Avatar
85 ft-lbs for the larger diameter bolts and 30lb-ft for the smaller diamet bolts.
Old Sep 24, 2003 | 10:05 AM
jmX's Avatar
jmX
You guys gotta understand that the whole point of a TTY bolt is that it's more accurate than a torque spec itself. Depending on any oil or grit that might be in the headbolt hole itself, 75lb ft might end up being more or less tight than 75lb feet on somebody elses car. The TTY angle will end up being the same no matter what the torque spec ends up being.
