Help me stroke my camaro
Old Nov 28, 2008 | 10:59 AM
nazztman4739's Avatar
Default Help me stroke my camaro
I am trying to stroke my camaro ls1 im thinking 383 3.90 stroke and a .030 overbore.What i need is i was told that anything under 4 inch stroke i dont need to do alot of clearancing is this true?? Help me out do u have any sugestions of a budget stroker kit ??
Old Nov 28, 2008 | 11:02 AM
i even have a yamaha warrior new top end not running needs some work ill trade for some ls1 or 2000 camaro parts
Old Nov 28, 2008 | 04:47 PM
the_merv's Avatar
Veteran: Air Force
You can run a 4.000" Crank without a problem in a LS1. 4.000" Crank with a Stock Bore is a 383, I don't think a LS1 will take a .030 over-bore.
Old Nov 28, 2008 | 05:16 PM
BlackScreaminMachine's Avatar
Internet Mechanic
LS1's cant take much more then a few hones... before sleeving is needed.
Old Nov 28, 2008 | 08:33 PM
david vericker's Avatar
4.00" stroke and a 3.905 bore = 383
Old Nov 29, 2008 | 04:19 PM
thank you for the info so i can stuff a 4 incher without modding the block?
Old Nov 29, 2008 | 07:25 PM
snake charmer's Avatar
remember when adding stroke , the pistons will move up and down quicker than normal . as long as it is built right you should be ok . otherwise may have to drop your rev limiter down .
