LS6 cam
Definately good for you.. wish I enjoyed it that much!
I'm running the GM ls6 heads and ls6 cam setup and make 410whp.. with stock gear it did 11.9 @ 118 full weight 6spd. LS6 cams do work!
I'm just saying to other guys that ARE looking for HP gains - the aftermarket cams will likely net you more noticeable improvements.
Ls6 cam,intake,heads stock will give you 400hp 356rwhp that's cool like having a ls6 in your car get the ls6 heads ported that will add another 20 rwhp and don't forget that's on a car without headers.lol
I'm not interested in winning a drag race. This car is mostly used for cruising in the country at sundown after a hot summer day.
As far as the cam selection, If you want some good power all through the rev range and decent mileage I would suggest the gm hot cam. It has a mild idle with good engine vacuum and is often reffered to as a starter cam. Coincidentally I am selling one that I put in my brothers truck for him since it is relatively mild and it was his DD.
Heres the sale thread if you are interested.
https://ls1tech.com/forums/lsx-parts...l#post11333786
