best oil viscocity/weight....
. 67K now and I think its time for some seafoam!!! Should i go with somethign heavier like 10W-30 to quite down the noise? I live in texas so it rarely gets below freezing so what do you guys recomend?-zach
-zach
Someone told me royal purple was terrible.... ok guys recomend me something that will quite my **** down some and doesnt rob too much power.
I used the RP 10-30 religiously and love it. I just switched to the Euro Castrol Syntec 5-40 and may like it better. I considered the Mobil 1 0-40 with "winter" here. Check out the boboilguy site, it's a great read, and make your call. Any good synthetic + filter every 5k or less will do you right. I've used RP 15-40 and felt it was too thick on startup, though it was nice once running. I am really liking the Syntec so far, it is quieter all the time.
To the guy that asked what part of Texas I live around houston.... I ended up cheaping out for the first time in awhile. A ******* bearing or something incredibly loud decided to go out the night before the oil change! So went with some castrol synthetic 10W-40. improved hardly at all. Guess I will have to change to change it again soon with some royal.
This syntec 10W-40 stuff any good?
Seafoam will be no help to you.
Another solution would be to add a cam with fast ramp rates so the valvetrain sewing machine sound drowns out the piston slap noise.
good luck
Carbon build up on the piston skirt often produces the slap/knock at cold start. This is why these motors are quiet when new but develop PS as they get more miles thus more carbon build-up. Seafoam can clean this carbon off resulting in less or eliminated PS for a while until it builds back up.
PS is caused by BOTH loose tolerances AND and the short piston skirt designed to reduce rotating mass on these pistons.
I usually run GC but decided to put in some cheaper semi-synthetic 5-30 since my winter-spring oil change comes up quicker. Piston slap got much worse. I'm going to go drain it now and replace it with GC.
I have noticed my piston slap get progressively worse in the 5 years and 43,000 miles I've driven the car.
