trick flow heads
Old Dec 28, 2008 | 08:09 AM
vsocks1's Avatar
Originally Posted by sublime1996525
The cam is a comp cams 232/234 595/598 112lsa. The springs are good up to a .650 lift. I wouldn't have thought valve float would've been an issue. I was told that shimming the springs should take care of the issue. Any ideas?
Let me know what ends up working for you. I am gathering parts for a very similar setup that I will install this spring.
