question about springs(in the head)
Old Dec 6, 2008 | 04:20 PM
96ta's Avatar
Default question about springs(in the head)
do you think it would be overkill for me to get dual valve springs for a baby cam ie tr224? would i have to worry about too much clamp pressure?
Old Dec 7, 2008 | 01:27 AM
letsrunem's Avatar
Dual springs are not necessary for that size cam.
Old Dec 7, 2008 | 02:20 AM
the_merv's Avatar
Yea, that Cam is small..
Old Dec 7, 2008 | 05:34 AM
96ta's Avatar
thank you for pointing out the obvious.
Old Dec 7, 2008 | 06:14 AM
the_merv's Avatar
Thank you for being a douche..I was agreeing with the post above me and answering your question as well. Don't post if you can't take an answer.
Not my fault you got a small shaft..
Old Dec 7, 2008 | 06:17 AM
99FormulaM6's Avatar
what lift is it going to be?
Old Dec 7, 2008 | 06:35 AM
the_merv's Avatar
I looked it up on their site and it's a .563 Lift, Intake and Exhaust.
Old Dec 7, 2008 | 09:33 AM
Ryan02SS's Avatar
I ran Patriot Golds for almost 25K miles on my TR224 with no problems and the car ran awesome and made good power. Checking pressure showed only a few psi drop after 25K miles. Previous springs were bluestripe 918s that were down 20-25psi after only 10K miles.
I say use a good dual spring.
Old Dec 7, 2008 | 11:09 AM
SladeX's Avatar
30k miles now and TR224 and patriot gold duals, working fine so far, I have heads waiting to go in with yet again patriot gold duals on them.
Old Dec 7, 2008 | 11:31 AM
BAD2000TA's Avatar
I had Comp 918's on MTI's Stealth II cam (224/220 .580ish lift). Unfortunately, I had one of the bad 918 batchs and an exhaust valve spring broke after 4000 miles. Consequently, piston hit the valve, blowing the motor (two holes in block, piston destroyed, rod in many pieces!).
Had I used a double spring, the motor might have survived. I built a new motor and used Patriot Gold double springs. It's just good insurance.
Old Dec 7, 2008 | 12:24 PM
405HP_Z06's Avatar
Always run good valve springs. This is not an area to use bargain parts. I prefer Crane 144833's, PSI 1511's, or PAC 1518's.
Old Dec 7, 2008 | 02:28 PM
vettenuts's Avatar
Please provide your basis for this statement?
To the OP:
You need adequate seat and open valve spring forces for the cam. If you are staying with beehives, I would agree with the prior post that PSI 1511's or PAC 1518's are the best bet and due to the material processing they will provide excellent valve spring life. As for duals, then the Patriots would be more than adequate.
If you error on seat forces with valve springs, always error on the high side. The low side can float the valve train or cause valve bounce both of which can result in major problems down the road.
Old Dec 7, 2008 | 03:55 PM
96ta's Avatar
thats part of why i was thinking to do dual.
as for merv well i wasnt trying to sound like a douchebag i just thought your post had nothing to it. anywho we all know its not the size of the boat but the motion in the ocean.
