58cc heads
Old Dec 9, 2008 | 01:55 PM
02b4ccamaro's Avatar
Default 58cc heads
is a head w/a 58cc combustion chamber streetable? ive seen that w/ a 58cc combustion chamber and a stock head gaskit that you will have a campression ratio of over 11.5to1 . is this to high to run on pump gas, and will it be streetable?
Old Dec 9, 2008 | 02:09 PM
First Collision's Avatar
That's cutting it damn close for pump gas.. I wouldn't recommend it. gains aren't going to be worth it.
Old Dec 9, 2008 | 02:23 PM
Sigforty's Avatar
It is streetable. I ran 58 cc heads with a stock head gasket on my 346, and am now running 58 cc heads with stock gaskets on my 383. I have around 11.8 static CR right now, and do not have any issues. What you need to watch is your DCR.
Old Dec 9, 2008 | 02:31 PM
And the dcr can be effected by the cam opening events corrcted? and is there a formula to determine this?
Old Dec 9, 2008 | 06:35 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
^ Quite a few people have made calculators regarding DCR on here. If you search DCR calculator you should be able to find it.
Old Dec 10, 2008 | 09:24 PM
JimMueller's Avatar
58cc here, with .040 cometics, daily driven in Florida. 93 octane.
Old Dec 10, 2008 | 10:23 PM
on2's Avatar
on2
Depends on your DCR which depends on your camshaft.
Search for the Piano Prodigy DCR calculator.
Patrick G used 57cc with 0.041 head gasket.
